Skip to content
Sovol Comgrow T500 3D Printer | Review 2024
Reviewed by 3DPrinterLab
Product Overview
Sovol Comgrow T500 3D Printer, this powerful machine is designed to unleash your creativity and bring your grand-scale projects to life with exceptional finesse.
Introduction to the Sovol T500 3D Printer
On the market for a 3D printer that can handle large-scale projects with ease? Look no further than the Sovol T500. With its extensive printing area of 500*500*500mm, this printer is capable of producing high-quality prints with precision and accuracy.
Key Features and Capabilities
Assuming you’re looking for a 3D printer that can deliver exceptional results, the Sovol T500 has got you covered. Here are some of its key features:
  • Extra-large printing area of 500*500*500mm
  • Max speed up to 500mm/s with direct drive extruder and 6.5:1 gear ratio
  • 300°C high-temp printing with all-metal hotend and hardened nozzle
  • Compatible with a wide range of materials, including TPU, PETG-CF, PLA, PETG, Carbon Fiber, and Wood
  • 7″ Klipper firmware touch screen with 1024*600 resolution
  • Industrial-grade internal linear rails on XYZ Axis for smoother movements
  • Dual Y&Z axis design for more stable and precise printing
  • 95% pre-assembly for easy setup and reduced assembly troubles
  • 49-point auto leveling for precise calibration
This impressive list of features makes the Sovol T500 an ideal choice for anyone looking to produce high-quality prints with ease and efficiency.
Product design and functionality are crucial aspects of any 3D printer. The Sovol T500 boasts a robust design with industrial-grade internal linear rails on XYZ Axis, ensuring smoother movements and reducing friction. The printer’s hotend is equipped with LED lights, allowing you to monitor prints even in low-light conditions. Additionally, the Sovol T500 can be controlled via WiFi transmission for seamless operation remotely. With its advanced features and capabilities, this printer is perfect for anyone looking to take their 3D printing experience to the next level.
Print Performance
The Sovol T500 3D printer is designed to deliver exceptional print performance, making it an ideal choice for grand-scale projects and batch production. With its advanced features and upgraded design, you can expect fast, efficient, and high-quality prints.
Fast Klipper Firmware for Enhanced Speed and Efficiency
One of the standout features of the Sovol T500 is its fast Klipper firmware, which enables you to achieve remarkable print speeds of up to 500mm/s. This means you can complete your prints significantly faster, saving you time and increasing your productivity.
Large Print Volume for Grand-Scale Projects
Enhanced by its large print volume of 500x500x500mm, the Sovol T500 allows you to bring your grand-scale projects to life with exceptional finesse. You can print larger objects or produce multiple items in a single batch, making it an ideal choice for entrepreneurs and hobbyists alike.
With such a spacious print volume, you can explore new possibilities in 3D printing, from creating complex models to producing functional prototypes. The Sovol T500’s large build volume also enables you to print multiple objects simultaneously, streamlining your workflow and increasing your overall efficiency.
Design and Construction
Some of the most impressive aspects of the Sovol T500 3D printer are its design and construction. The printer’s extra-large build volume and industrial-grade internal linear rails on the XYZ axis make it stand out from other 3D printers on the market.
Linear Rails for Stability and Smooth Motion
The Sovol T500 features linear rails that provide stability and smooth motion, allowing for precise and accurate prints. These rails reduce friction, enabling the print head to move smoothly and consistently, resulting in superior print quality.
Industrial-Grade Internal Linear Rails on XYZ Axis
The industrial-grade internal linear rails on the XYZ axis are a notable feature of the Sovol T500. These rails are designed to reduce friction and provide smooth motion, ensuring that your prints turn out precise and accurate.
Design-wise, the internal linear rails on the XYZ axis are a game-changer. They allow for more stable and precise movement of the print head, which in turn improves layer alignment and reduces layer shifting. This results in prints with exceptional detail and accuracy. With these rails, you can expect superior print quality and reduced warping, making the Sovol T500 an excellent choice for printing large and complex models.
User Experience
For a seamless and enjoyable 3D printing experience, the Sovol T500 has been designed with user-friendliness in mind.
Intuitive Interface and Easy-to-Use Controls
On the 7-inch Klipper firmware touch screen, you’ll find an intuitive interface that makes it easy to navigate through settings and options. The controls are responsive and straightforward, allowing you to focus on your prints without any hassle.
Convenient Setup Process and 95% Pre-Assembly
While other 3D printers may require hours of assembly and setup, the Sovol T500 takes only 15 minutes to get started. With 95% pre-assembly, you can simply plug and play, saving you time and effort.
Controls are designed to be user-friendly, and the pre-assembly process ensures that you can start printing quickly. You won’t need to spend hours assembling the printer or configuring settings, allowing you to focus on bringing your ideas to life.
Print Quality and Speed
Unlike many other 3D printers on the market, the Sovol T500 stands out with its exceptional print quality and impressive speed. Let’s dive deeper into what makes this printer so remarkable.
Achieving Superior Print Quality with Dual Y&Z Axis Design
While many printers struggle with layer shifting and misalignment, the Sovol T500’s dual Y&Z axis design ensures a more stable and precise printing process. This innovative design feature allows for smoother movements of the print head, resulting in superior print quality and reduced layer shifting.
Max Speed up to 500mm/s for Efficient Printing
Axis-parallel motion enables the Sovol T500 to reach incredible speeds of up to 500mm/s, making it one of the fastest 3D printers in its class. This means you can print complex models quickly and efficiently, saving you valuable time and increasing your productivity.
Plus, the printer’s direct drive extruder with a 6.5:1 gear ratio and 50N pulling strength ensures consistent extrusion and precise retraction, allowing you to achieve the best print quality at high speeds. With the Sovol T500, you can print complex models quickly and efficiently, making it an ideal choice for batch production and large-scale projects.
If you're considering purchasing the Sovol Comgrow T500 after reading this review, don't miss out on exclusive discounts available through Wethrift! Click the link to save on your purchase today.
Q: What is the print volume of the Sovol T500 3D printer?
A: The Sovol T500 3D printer has an extensive print volume of 500mm x 500mm x 500mm, allowing you to bring grand-scale projects to life with exceptional finesse. This large build volume also enables batch production in one time.
Q: What makes the Sovol T500 3D printer’s hotend special?
A: The Sovol T500 3D printer’s hotend is all-metal and equipped with a hardened nozzle, which enhances wear-resistance and enables printing of mixed carbon fiber or more abrasive and exotic filaments. The hotend can be heated to 300°C, making it compatible with a wide range of filaments, including TPU, PETG-CF, PLA, PETG, Carbon Fiber, and Wood.
Q: What are the benefits of the Sovol T500 3D printer’s industrial-grade internal linear rails on XYZ Axis?
A: The industrial-grade internal linear rails on XYZ Axis of the Sovol T500 3D printer reduce friction, offering smoother movements of the print head. This improves layer alignment, reduces layer shifting, and achieves superior print quality. Additionally, the dual Y&Z axis design enables the printing process to be more stable and precise.
Cart 0
Your cart is currently empty.
Start Shopping
