Key Benefits of PETG:
Durability: Stronger than PLA and ABS, making it ideal for load-bearing or functional parts.
Flexibility: More impact-resistant and less brittle than PLA.
Chemical Resistance: Withstands water, acids, and alkalis—suitable for industrial and outdoor applications.
Transparency: Naturally semi-transparent, great for visual or lighting-based designs.
Food Safety: Some PETG brands are certified food-safe (check individual product specs).
Pros:
Cons:
Use Cases:
Recommended PETG Filament:
PLA (Polylactic Acid)
Key Benefits of PLA:
Ease of Use: Prints at a lower temperature (180-220°C) and typically doesn’t require a heated bed.
Eco-Friendly: Biodegradable and suitable for indoor use.
Detail Precision: Delivers high-quality surface finish and fine detailing.
Tips:
Use Cases:
Recommended PLA Filament:
Key Benefits of ABS:
High Strength & Toughness: Great for parts that need to withstand physical stress or wear.
Heat Resistance: Maintains performance at higher temperatures—ideal for automotive or outdoor use.
Post-Processing Friendly: It can be sanded, smoothed with acetone vapor, or painted easily.
Tips:
Use Cases:
Optimize 3D printing quality by adjusting layer height, infill density, and patterns. Achieve stronger, smoother, and more efficient prints with these tips.
