Sovol Resin Vat for Elegoo Mars and Anycubic Photon (S) / Mono
I purchased the Sovol resin vat as I wanted an additional resin vat so that I did not have to keep swapping the resin as I use two or three types on a regular basis.
The vat is only sold for the Elegoo Mars / Anycubic Photon and Photon S but after a quick email and very fast response I was told that it should fit the Mono as the indents for the securing screws are elongated to fit various machines. You can see this in the attached photo.
The vat is slightly smaller in width than the original Mono vat, however the plate fits perfectly without any issues as you can see from the photo.
The vat has an especially useful measuring marker in white against the black so you can see how much resin you have poured in. These are easier to see that the black on black that are imprinted on the plastic OEM vat you get with the Mono. This is printed on so I cannot guarantee how long this will last, however it's certainly better than nothing.
Unlike the Mono vat this is a nice hefty alloy, not plastic. It has two rubber covers to put over the top and bottom of the vat. These have the dual purpose of both a UV blocker, so that any resin stored in the vat will not cure, as well as protection for the FEP so that it will not get scratched when put on a surface. The covers fit the original vat so can be used to protect the resin and FEP when that vat is not being used.
The FEP is held in place with the standard two metal ring system and was perfectly tensioned. I tested this by performing a test print using one of my standard resins and a standard print which worked perfectly well. This print covers at least 60% of the plate so caused enough suction to test the FEP.
Considering the price for this vat is just £22.99 compared to a standard Anycubic replacement at £35.99, this a bargain.
This certainly deserves five stars out of five as its as better than the original at two thirds of the price. Their customer service also seems measurably better than Anycubic.
Credit to
Approved to share as a blog.
C&C Designs on facebook
34 comments
https://support.×1.com/link.html?https://joinlive77.com/ https://themixer.ru/go.php?url=https://joinlive77.com/ https://www.gotomypctech.com/affiliates/scripts/click.php?a_aid=ed983915&a_bid=&desturl=https://joinlive77.com/ https://rx.dragonroids.com/links/https://joinlive77.com/ https://www.pbitennis.com/Redirect.aspx?destination=https://joinlive77.com/ https://www.analogmensch.de/externalcontent/links.php?url=https://joinlive77.com/ https://www.serbiancafe.com/lat/diskusije/new/redirect.php?url=https://joinlive77.com/ https://www.megavision.net/hitting.asp?id=1406&url=https://joinlive77.com/ http://cmkvadrat.com/bitrix/rk.php?goto=https://joinlive77.com/ http://www.prakrity.net/cgi-bin/ewf/prakrity_com/scripts/ewf_page_loader_prakrity_com.cgi?page=external&location=https://joinlive77.com/ https://visit-thassos.com/index.php/language/en?redirect=https://joinlive77.com/ https://www.motownindia.com/AdRedirector.aspx?ad=59&target=https://joinlive77.com/ https://vastsverige.imagevault.se/mediagallery/details?take=432&mediaid=52597&downloadurl=https://joinlive77.com/ https://www.bildungszentrum-gesundheit.de/expertengespraeche/2012/?jumpurl=https://joinlive77.com/ http://adserver.plus.ag/revive/www/delivery/ck.php?ct=1&oaparams=2__bannerid=133__zoneid=9__cb=b6ec93b620__oadest=https://joinlive77.com/ https://www.biomar.com/userauthentication/logout/?returnUrl=https://joinlive77.com/ https://adm.chedot.com/link/?link=https://joinlive77.com/ https://www.mtnplay.com.gh/portal/redirect.aspx?rurl=https://joinlive77.com/ https://hotcakebutton.com/search/rank.cgi?mode=link&id=181&url=https://joinlive77.com/ http://mail.resen.gov.mk/redir.hsp?url=https://joinlive77.com/ https://mktdomercado.sitesdomercado.com.br/campanhas/redirecionar?url=https://joinlive77.com/ https://la2vampire.ru/go.php?go=https://joinlive77.com/ https://www.weather.net/cgi-bin/redir?https://joinlive77.com/ https://ukrface.com.ua/away.php?url=https://joinlive77.com/ http://3dsexmadness.com/cgi-bin/atc/out.cgi?id=105&u=https://joinlive77.com/ https://www.brus-ok.ru/bitrix/redirect.php?goto=https://joinlive77.com/ https://www.seankenney.com/include/jump.php?num=https://joinlive77.com/ https://track.twshop4coupon.com/track/clicks/3171/c627c2b89e0522dbfe9cbd2e8d2b8914736245cb75e9f0ab416db1046005?t=https://joinlive77.com/ https://web27.secure-secure.co.uk/taichilink.co.uk/healthqigong.org.uk/members/log_out_s.php?return_page=https://joinlive77.com/ https://www.d-e-a.eu/newsletter/redirect.php?link=https://joinlive77.com/ https://www.intersoft.ir/go.php?https://joinlive77.com/ https://www.mydosti.com/Advertisement/updateadvhits.aspx?adid=48&gourl=https://joinlive77.com/ https://www.wifesharingpics.com/web/cgi/out.php?url=https://joinlive77.com/ https://ad.dyntracker.com/set.aspx?dt_url=https://joinlive77.com/ https://malehealth.ie/redirect/?age=40&part=waist&illness=obesity&refer=https://joinlive77.com/ https://infosort.ru/go?url=https://joinlive77.com/ http://str.pwwq.com/teen/out.cgi?id=10346&url=https://joinlive77.com/ https://www.hudsonvalleytraveler.com/Architecture/Redirect?redirect_url=https://joinlive77.com/ http://rudeextreme.com/out.php?https://joinlive77.com/ https://caba.de/CaBaFoRuM/index.php?p=https://joinlive77.com/ https://buyer-life.com/redirect/?url=https://joinlive77.com/ https://www.wblib.org/includes/statistics.php?StatType=Link&StatID=Instagram&weblink=https://joinlive77.com/ https://fortune-bbs.com/jump.php?url=https://joinlive77.com/ http://clicktrack.pubmatic.com/AdServer/AdDisplayTrackerServlet?clickData=JnB1YklkPTE1NjMxMyZzaXRlSWQ9MTk5MDE3JmFkSWQ9MTA5NjQ2NyZrYWRzaXplaWQ9OSZ0bGRJZD00OTc2OTA4OCZjYW1wYWlnbklkPTEyNjcxJmNyZWF0aXZlSWQ9MCZ1Y3JpZD0xOTAzODY0ODc3ODU2NDc1OTgwJmFkU2VydmVySWQ9MjQzJmltcGlkPTU0MjgyODhFLTYwRjktNDhDMC1BRDZELTJFRjM0M0E0RjI3NCZtb2JmbGFnPTImbW9kZWxpZD0yODY2Jm9zaWQ9MTIyJmNhcnJpZXJpZD0xMDQmcGFzc2JhY2s9MA==url=https://joinlive77.com/ https://enersoft.ru/go?https://joinlive77.com/ https://topmagov.com/redirect?url=https://joinlive77.com/ http://www.dsl.sk/article_forum.php?action=reply&forum=255549&entry_id=147673&url=https://joinlive77.com/ https://medakahonpo.com/MT/index.cgi?id=1&mode=redirect&no=578&ref_eid=3332&url=https://joinlive77.com/ http://www.stopdemand.org/ra.asp?url=https://joinlive77.com/ https://managementportal.de/modules/mod_jw_srfr/redir.php?url=https://joinlive77.com/ https://www.mesteel.com/cgi-bin/w3-msql/goto.htm?url=https://joinlive77.com/ https://cms.mobidaze.com/m/mobidazehandp21915/print_url.php?url=https://joinlive77.com/ https://horsesmouth.com/LinkTrack.aspx?u=https://joinlive77.com/ https://www.trackroad.com/conn/garminimport.aspx?returnurl=https://joinlive77.com/ https://www.erotiektube.nl/out.php?url=https://joinlive77.com/ https://www.wsearch1.com/redirect.aspx?url=https://joinlive77.com/ https://kauppa.waltti.fi/redirect-to-lang/?lang=fi&url=https://joinlive77.com/ https://www.sante-dz.org/doc.php?url=https://joinlive77.com/ http://www.cnainterpreta.it/redirect.asp?url=https://joinlive77.com/ https://screenmediafilms.net/out/watch/486?link=https://joinlive77.com/ http://rayadistribution.com/AdRedirect.aspx?Adpath=https://joinlive77.com/ https://beton.ru/redirect.php?r=https://joinlive77.com/ https://www.oltv.cz/redirect.php?url=https://joinlive77.com/ http://www.hirforras.net/scripts/redir.php?url=https://joinlive77.com/ https://www.rprofi.ru/bitrix/redirect.php?goto=https://joinlive77.com/ http://www.tonysteenies.com/cgi-bin/a2/out.cgi?id=596&u=https://joinlive77.com/ http://timemapper.okfnlabs.org/view?url=https://joinlive77.com/ https://www1.arbitersports.com/Content/HideMobileAlerts.aspx?redirectUrl=https://joinlive77.com/ https://www.kyrktorget.se/includes/statsaver.php?type=kt&id=8517&url=https://joinlive77.com/ https://www.onerivermedia.com/blog/productlauncher.php?url=https://joinlive77.com/ https://www.lifetimetraining.fusion-universal.com/redirect?to=https://joinlive77.com/ https://www.schooling.gr/linkredir.asp?aid=51&link=https://joinlive77.com/ https://mkt.qisat.com.br/registra_clique.php?id=TH|teste|194616|690991&url=https://joinlive77.com/ https://willowtownprimary.co.uk/bgp/primary/fbhw/CookiePolicy.action?backto=https://joinlive77.com/ http://alyasoft.com/catalog/redirect.php?action=url&goto=https://joinlive77.com/ https://www.mytrafficcoop.com/members/clicks.php?tid=small_ad&loc=loginpage&id=601&url=https://joinlive77.com/ http://www.nlamerica.com/contest/tests/hit_counter.asp?url=https://joinlive77.com/ http://www.laosubenben.com/home/link.php?url=https://joinlive77.com/ http://dyna.boe.ttct.edu.tw/netlink/hits.php?id=438&url=https://joinlive77.com/ https://www.vasabladet.fi/ViewSwitcher/SwitchView?mobile=False&returnUrl=https://joinlive77.com/ https://knitty.com/banner.php?id=1549&url=https://joinlive77.com/ https://www.abcplus.biz/cartform.aspx?returnurl=https://joinlive77.com/ https://www.magazinzeny.cz/?b=2118442568&redirect=https://joinlive77.com/ https://sso.esolutionsgroup.ca/default.aspx?SSO_redirect=https://joinlive77.com/ https://cstb.ru/bitrix/redirect.php?goto=https://joinlive77.com/ https://b2c.hypernet.ru/bitrix/rk.php?goto=https://joinlive77.com/ http://m.shopinboise.com/redirect.aspx?url=https://www.www.https://joinlive77.com/ http://www.denwer.ru/click?https://joinlive77.com/ https://ishchenko.info/redirect?url=https://joinlive77.com/ https://www.ibmp.ir/link/redirect?url=https://joinlive77.com/ http://www.wicosports.org/Redirect.aspx?destination=https://www.www.https://joinlive77.com/ https://www.etypeservices.com/Flash/LinkRedirection.aspx?IssueID=46912&Returnurl=https://joinlive77.com/ http://www.equipment-trade.ru/r.php?urllink=https://joinlive77.com/ https://www.findyello.com/redirector.php?yelref=https://joinlive77.com/ http://ram.ne.jp/link.cgi?https://joinlive77.com/ https://www.motociclete-de-vanzare.ro/?view=mailad&cityid=-1&adid=14661&adtype=A&urlgood=https://joinlive77.com/ https://www.dapr0n.com/rel/out.php?u=https://joinlive77.com/ https://virink.com/away?to=https://joinlive77.com/ https://www.tremblant.ca/Shared/LanguageSwitcher/ChangeCulture?culture=en&url=https://joinlive77.com/ http://www.site-navi.net/sponavi/rank.cgi?mode=link&id=890&url=https://joinlive77.com/ https://www.vacationsfrbo.com/redirect.php?property_id=27796&website=https://joinlive77.com/ https://www.sindbadbookmarks.com/japan/rank.cgi?mode=link&id=3393&url=https://joinlive77.com/ https://movil.todorelatos.com/url.php?q=https://joinlive77.com/ https://imbir.biz/bitrix/redirect.php?goto=https://joinlive77.com/ https://devfix.ru/bitrix/rk.php?goto=https://joinlive77.com/ http://www.yo-nigga.com/cgi-bin/a2/out.cgi?id=66&l=main&u=https://joinlive77.com/ http://www.sm-bomber.com/mkr/out.cgi?id=02005&go=https://joinlive77.com/ https://www.abiturient.ru/bitrix/rk.php?id=61&site_id=ab&goto=https://joinlive77.com/ http://m.shopinbuffalo.com/redirect.aspx?url=https://www.www.https://joinlive77.com/ https://juicystudio.com/services/readability.php?url=https://joinlive77.com/ https://mrg037.ru/bitrix/rk.php?goto=https://joinlive77.com/ http://incestfire.com/out.php?p=51&url=https://joinlive77.com/ https://lirasport.com.ar/bloques/bannerclick.php?id=7&url=https://joinlive77.com/ http://www.hanbaisokushin.jp/link/link-link/link4.cgi?mode=cnt&hp=https://joinlive77.com/ https://caminhoesecarretas.com.br/redirect.aspx?id=1083&url=https://joinlive77.com/ https://ns.ru/bitrix/redirect.php?goto=https://joinlive77.com/ http://www.e-tsuyama.com/cgi-bin/jump.cgi?jumpto=https://joinlive77.com/ https://www.headlinemonitor.com/SicakHaberMonitoru/Redirect/?url=https://joinlive77.com/ http://www.zoosex.cc/out.php?url=https://joinlive77.com/ https://nieuws.rvent.nl/bitmailer/statistics/mailstatclick/42261?link=https://joinlive77.com/ https://www.hendersonville.com/cgi-bin/click.cgi?id=hendersonvilleeurgentcare&url=https://joinlive77.com/ https://app.randompicker.com/Info/AccessDenied.aspx?Url=https://joinlive77.com/&Culture=ru-RU https://www.isitmeorisdown.com/https://joinlive77.com/ http://www.google.hu/url?sa=t&url=https://joinlive77.com/ http://maps.google.hu/url?sa=t&url=https://joinlive77.com/ http://images.google.hu/url?sa=t&url=https://joinlive77.com/ http://webfeeds.brookings.edu/%7E/t/0/0/%7Ewww.https://joinlive77.com/ https://www.weebly.com/domains?search=joinlive77.com https://www.gmanetwork.com/news/#/search;query=joinlive77.com https://edex.adobe.com/search?q=joinlive77.com https://search.usa.gov/search?utf8=%E2%9C%93&affiliate=www.healthit.gov&query=joinlive77.com https://www.tumblr.com/search/joinlive77.com/ https://www.deviantart.com/search?q=joinlive77.com/ https://domains.lycos.com/search/?search=joinlive77.com/ https://www.instructables.com/howto/JOINLIVE77.COM/ https://discover.hubpages.com/search?query=joinlive77.com/ https://www.imp.mx/salto.php?va=https://joinlive77.com/ https://splash.hume.vic.gov.a u/analytics/outbound?url=https://joinlive77.com/ http://www.tupassi.pr.gov.br/enquete/enquete.php?id_cliente=1027&url=https://joinlive77.com/ https://rspcb.safety.fhwa.dot.gov/pageRedirect.aspx?RedirectedURL=https://joinlive77.com/ https://www.fhwa.dot.gov/reauthorization/reauexit.cfm?link=https://joinlive77.com/ http://onlinemanuals.txdot.gov/help/urlstatusgo.html?url=https://joinlive77.com/ https://www.wrasb.gov.tw/opennews/opennews01_detail.aspx?nno=2012011201&return=https://joinlive77.com/ https://www.wrasb.gov.tw/opennews/opennews01_detail.aspx?nno=2014062701&return=https://joinlive77.com/ https://rspcb.safety.fhwa.dot.gov/pageRedirect.aspx?RedirectedURL=https://joinlive77.com/ https://www.wrasb.gov.tw/opennews/opennews01_detail.aspx?nno=2014062701&return=https://joinlive77.com/ https://splash.hume.vic.gov.au/analytics/outbound?url=https://joinlive77.com/ https://www.wrasb.gov.tw/opennews/opennews01_detail.aspx?nno=2012011201&return=https://joinlive77.com/ http://www.tupassi.pr.gov.br/enquete/enquete.php?idcliente=1027&url=https://joinlive77.com/ https://www.fhwa.dot.gov/reauthorization/reauexit.cfm?link=https://joinlive77.com/ http://onlinemanuals.txdot.gov/help/urlstatusgo.html?url=https://joinlive77.com/ https://clubs.london.edu/click?uid=24ce7c96-76b4-11e6-8631-0050569d64d5&r=https://joinlive77.com/ https://www.nbc.edu/videoplayer.php?u=https://joinlive77.com/ http://www.is.kyusan-u.ac.jp/htmllint/htmllint.cgi?ViewSource=on;URL=https://joinlive77.com/ http://rs.rikkyo.ac.jp/rs/error/ApplicationError.aspx?TopURL=https://joinlive77.com/ https://publishing.brookes.ac.uk/?URL=https://joinlive77.com/
Got my loans down to exactly $126,000! ???? This 0% partial is quite minute, as a matter of fact seeing the amount lead down, genius if I had the funds I’d principled give someone a kickback it afar all at once ?? I’m on edge when the for the present comes and moment is underwrite on FedLoan it will be super difficult to fee idle my loans, I heard inseparable chick owed 80k and then after she paid it mistaken she even now owed 120k, like god I promise I don’t ruin up in a be like place ?? Anyways it’s valid likeable seeing the actual amount of cold hard cash work down, like I’m making increase destined for once in a while ???? mentation I’d share, not as depressed as in the vanguard lmao do student loans get forgiven after 25 years (This does not figure on an added apprentice Sallie Mae allowance of 30k my mom is paying seeking me bless her basics)
555
555
555
555
555
555
555
555
555
555
555
555
555
1; waitfor delay ‘0:0:12’ -
(select(0)from(select(sleep(12)))v)/‘(select(0)from(select(sleep(12)))v)’“(select(0)from(select(sleep(12)))v)”/
0"XOR(if(now()=sysdate(),sleep(12),0))XOR"Z
0’XOR(if(now()=sysdate(),sleep(12),0))XOR’Z
1" OR 2+554-554-1=0+0+0+1 -
190’
-1’ OR 2+420-420-1=0+0+0+1 or ‘8Yt2XTbn’=’
1’ OR 2+719-719-1=0+0+0+1 -
1 OR 2+220-220-1=0+0+0+1 -
1
2
NextLeave a comment
