What size belt does the SV01 Use?
y-axis:2GT, W6, rubber, black L937mm
X-axis: 2GT, W6, rubber, black L900mm
Silent mainboard+BL Touch+touch screen firmware(marked in the picture)
Link: https://drive.google.com/file/d/1KVY9NZb95y4N6eMan5pRTklwFEFOS3VY/view
The screen for the printer turns on and you don't have a display on it, it's just a blue screen
Please re-plug both ends of the display cable to ensure that it is firmly inserted and not damaged.
Except for the power supply cable and the display cable, unplug all other cables on the mainboard. Power on to see if the screen will light up.
Connect the computer with a USB cable and turn it on to see if the screen lights up.
Try to refresh the motherboard firmware.
Firmware:
https://drive.google.com/file/d/1qYl9oV2Ve3wNDroG113tZ-vIMQyD8-6v/view
Tutorial: https://www.youtube.com/watch?v=tkZvsjRoVgU
10 comments
Wow, happy to see this awesome post. I hope this think help any newbie for their awesome work. By the way thanks for share this awesomeness from Feel free to visit my website ! 먹튀 검증 순위 안전 카지노 코인 카지노 안전 토토 사이트 먹튀 검증 커뮤니티 https://www.j9korea.com
how to unjam filiment
Another day where sovol doesn’t answer their tech support. Another 24 hrs of this and I’m disputing my charges with my bank and throwing this printer in the dumpster
Just bought sc01. Contacted support but you guys won’t answer me. Heats up but restarts after initialization.
Ho appena comprato la stampante, ma purtroppo non si accende nonostante tutti i cavi collegati, non capisco quale sia il problema, inoltre é arrivata con dei graffi sui supporti
Is there a Canadian Store / web site to get parts, filament, printers, etc. Thanks in advance, Sylvain Sigouin
Hello, I ordered the sovol sv01 motherboard 2.2.1 and when i installed it the screen turned on with no logo and the motherboard has multiple flashing blue lights. ORDER #23004
Does the SV04 IDEX 3D Printer Metal Direct Drive Extruder work with sv01 printer? Best regards, Fred
BONJOUR? SUITE AU REMPLACEMENT DU PLATEAU JAI VOULU REGLER LE z OFFSET EN SUIVANT LA PROC2DURE MAI IMPOSSIBLE DE DESCENDRE AU DESSOUS DE O? POURQUOI ?
see if you can help me. my sovol s1 is crashing on the z axis it doesn’t add up to more than 25 centimeters i just bought this printer
