2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
發表評論
在發布之前,所有評論都會進行調節。
博客文章
查看全部
SV07 vs SV07 Plus: Discover the Key Differences
SV07 vs SV07 Plus:發現關鍵差異
比較Sovol SV07與SV07加3D打印機。發現構建尺寸,功能和定價方面的差異,以選擇滿足您的打印需求的最佳選擇。
FilamentHow to Eliminate Stringing in 3D Printing: 5 Proven Solutions
Stringing—those annoying spiderweb-like strands of plastic that appear between gaps in your 3D prints—is a common frustration for FDM 3D printer users. When the nozzle moves across open spaces, mel...
Klipper vs Marlin:哪種固件實際上可以提高您的打印速度?
Klipper vs Marlin:哪種固件提高了打印速度? Klipper在高級功能方面脫穎而出,而Marlin提供了簡單性和可靠性。
