Skip to content
Customizing and Upgrading Voron-Inspired Printers: A Guide for Enthusiasts
3D Printer enthusiasts are searching for machines with high-end performance that provide flexibility, precision, and the ability to be customized. One machine that has attracted my interest is the Sovol SV08, inspired by the highly regarded Voron 2.4.
The Voron design is based on the core-xy motion system, which includes a rigid frame and direct drive extrusion. It offers high precision and speed while minimizing mechanical problems.
What is the Design Theme Behind SV08?
Beginning with Voron 2.4 up to Sovol SV08
The Sovol SV08 draws heavily from the design principles used by the renowned Voron 2.4 CoreXY 3D printer known for its strength and precision. Both printers use the CoreXY mechanism, which is highly regarded for its ability to attain fast printing speeds and precise prints by reducing friction and mechanical complexity.
The CoreXY belt and pulley design allows quick movement, resulting in less stress on the motors. This design feature guarantees that users will consistently attain quality prints.
Additionally, the sturdy frame structure of these printers helps reduce vibrations while printing, further improving print accuracy. The Voron 2.4, known for its extensive customization capabilities and flexibility, is the basis for the SV08, which carries some of its structural advantages and offers more flexibility right out of the box.
What Are The Key Features of Sovol SV08?
1. 90% Pre-Assembled:
One of the best characteristics of the SV08 is that it arrives 90% pre-assembled. This dramatically reduces the setup time, making it more accessible even to people unfamiliar with 3D printing. Contrary to Voron 2.4, which typically requires a long and intricate assembly, the SV08 is ready to print in a 1-hour set up.
This speedy setup can be a huge advantage for hobbyists or professionals who would prefer to spend less time preparing and building. The pre-assembled structure also decreases the chance of errors in assembly that could lead to problems with hardware and print issues.
2. Cost-Effectiveness:
The SV08 is touted as a cheaper replacement for Voron 2.4. It comes with similar top-of-the-line features for a 1/2 price, which makes high-quality 3D printing more accessible to a wider population.
The lower cost does not mean sacrificing quality since the SV08 has a solid design and durable performance. Offering a high-quality and cost-effective opportunity, Sovol aims to provide the most advanced 3D printing technology accessible to more people, such as small educational institutions.
3. Open-Source Nature:
In keeping with the open-source philosophy, the SV08 lets users explore a variety of upgrades and modifications. The open-source model promotes community-driven development and allows people to contribute and use modifications to their hardware and firmware.
This is especially attractive to hobbyists and tinkerers who love personalizing their equipment. The open-source nature of the software also ensures that users can keep their equipment up-to-date with the latest developments in 3D printing without being tied to proprietary ecosystems.
What Are the Performance Characteristics of the SV08 Version?
1. High-Speed Printing:
The Voron SV08, just like Voron 2.4, is capable of high-speed printing. This is vital to reduce print times without sacrificing quality. This feature is especially useful for users who must print diverse prints at a time, for example, in a production setting or to speed up prototyping.
2. Sturdy frame:
Its sturdy style reduces vibrations, ensuring accurate and consistently printed prints. A solid frame is crucial for maintaining alignment and precision, particularly when printing at extreme speed or using high-temperature materials.
3. High-Temperature Compatibility:
The open source 3D Printer is compatible with high-temperature materials, extending the possibilities of applications from prototypes to functional components. This feature allows printers to print with advanced filaments which require higher extrusion temperatures and are renowned for their durability and strength.
This versatility makes the SV08 appropriate for printing parts that have to withstand mechanical stress, heat, and chemical exposure, making it more useful in different industrial and skillful environments.
4. User Experience:
The SV08 is created with the user in mind. Characteristics such as automated bed leveling, filament runout sensors, as well as a modular design that allows for simple upgrades and maintenance, improve the overall experience for users.
The bed leveling is automated to ensure that the bed of print is level before printing starts, which is essential for the adhesion of the first layer as well as the overall quality of the print.
Filament runout sensors warn the user that the filament is getting close to running out, thus preventing printing failures caused by filament exhaustion. The modular design lets users easily replace or upgrade parts to reduce downtime and maintenance costs.
How Do You Upgrade Your SV08?
Although the SV08 is well-equipped with all its features, many improvements and upgrades could improve its capabilities and performance.
Step 01: Enhancing Extruders
Upgrading the design of your extruder can significantly raise printing speed and filament feed quality. Alternatives like the StealthBurner, which is very popular with Voron fans, impart high performance and compatibility with the SV08's design.
The StealthBurner extruder is renowned for its dependability and capacity to work with various filament types, including composite and flexible materials. This modification could benefit from obtaining more uniform extrusion, lessen the risk of clogs, and improve the quality of prints overall.
Step 02: Firmware and Software Enhancements
Installing custom firmware like Klipper will unlock the latest options and improve efficiency. Klipper is a well-known option for its speedy printing capability and accurate controls, which can be set up to integrate seamlessly with SV08. This firmware supports multi-threading, which will boost the speed of printing and increase efficiency.
Furthermore, Klipper's ability to manage complex geometries and its advanced control algorithms could produce better-quality prints and fewer artifacts. Users also get an improved user interface and more customization features that are not included in the standard firmware.
Step 03: Frame and Structural Modifications
Reinforcing the printer's frame may benefit by reducing vibrations and increasing printing accuracy. Switching to more durable materials for critical components can improve the durability of the printer and its stability when operating at high speeds.
For instance, substituting new carbon or extra metal components could help provide an even more solid structure, reducing the chance of shifting or misalignments when printing.
Furthermore, adding vibration dampers and isolation mounts will further reduce the effects of external vibrations. This leads to more precise and smooth prints.
What are the Extra Modifications You Can Make on SV08?
1. StealthChanger and Tapchanger:
These mods provide advanced tools-changing capabilities, allowing the user to switch between several print heads in a snap. The StealthChanger replaces bearings using pins and bushings, which reduces friction and weight and improves the smoothness of movements.
The Tapchanger provides a sturdy and robust mechanism for changing tools that can accommodate several tool heads on one frame. These changes are still in development but have the potential to substantially increase the flexibility and performance of the SV08.
2. Modular Hotend System:
A modular hotend will allow you to change between types and sizes of nozzles and accommodate a broad range of printing materials and needs.
Modular hotends are also easier to maintain by allowing users to quickly replace a clogged or damaged part without removing the whole extruder. Some of the most popular choices are E3D V6 and Mosquito hotends, renowned for their reliability and performance.
3. Enhanced Cooling Strategies:
The most efficient cooling solutions are vital to maintain print quality, particularly when printing with high-temperature printing materials.
Upgrades to cooling systems, like adding extra cooling ducts could benefit to control the heat more effectively, decreasing the chances of warping and increasing the layer adhesion. The use of silent fans will help reduce the printer's noise, making it more appropriate to use in offices or at-home settings.
4. Modifications to the Bed:
The print bed is a different critical element that can benefit from improvements. Switching to a heated bed with a better temperature consistency can raise adhesion of the first layer and decrease the possibility of warping.
Also adding a smooth PEI (Polyethylenimine) sheet or glass bed would provide an even, smoother surface for printing and might make it easier to take out finished prints. Many users opt for magnetic beds, which allow simple swapping of the build surfaces.
What are the Most-Loved Community Upgrades?
The community of 3D printers is constantly creating new improvements and sharing the latest upgrades and improvements. Here are a few popular community-driven improvements to the SV08:
1. Linear Rail Upgrades:
Replacing the stock linear bearings with precision linear rails can dramatically improve printing quality and reduce noise. Linear rails bring greater stability and smoother motion, which is particularly useful for high-speed printing. This upgrade also increases the life of your printer by reducing wear on moving components.
2. Modifications to Tool Changers:
Advanced tool changer modifications, like those of StealthChanger and Tapchanger, allow diverse head sizes in one printer. This feature is particularly beneficial for multi-material printing and changing between different sizes of nozzles without manual intervention.
These modifications are complicated and could require major adjustments to the open source 3D Printer, but they are incredibly flexible and perform better for more advanced users.
3. Custom Enclosures:
Building a custom enclosure for the SV08 can help maintain a stable printing environment, which is crucial for printing with temperature-sensitive materials like ABS and nylon.
A custom enclosure can also help reduce noise and shield printing equipment from environmental elements.
Many users construct enclosures with features like filtered ventilation, internal lighting, and temperature control to improve their printing configuration.
4. Advanced Hotends:
Upgrading to more advanced hotends, like E3D V6 or the Mosquito Magnum E3D V6 or the Mosquito Magnum, could increase extrusion consistency and enable greater printing temperatures. These hotends were designed to provide high quality and durability, making them perfect for printing on many materials, including composites and flexible filaments.
Maintenance and Calibration for Voron-Inspired Printers
A proper maintenance schedule and calibration are crucial for ensuring the SV08 3D Printer runs smoothly and continues to create high-quality prints. Regular maintenance helps prevent common problems and can help you achieve consistently good outcomes. We will focus on routine maintenance tasks as well as the procedure for calibration to ensure that your 3D printer is in good condition.
1. Maintenance
Schedule maintenance prevents mechanical breakdowns and extends the life of your printer. Regular check-ups and minor adjustments can protect your printer from more serious issues in the future.
2. Lubrication
Moving Parts
The moving parts of your printer, like linear rails, need regular lubrication to work efficiently. Use a lubricant designed specifically for SV08 3D Printers or light machine oil. Use a tiny amount for the moving parts, then remove any excess to avoid dust buildup.
Rails and Bearings
For linear rails, apply a light amount of lubricant to prevent excess buildup. Clean the rails prior to applying lubricant to remove dust or dirt. The bearings must be regularly lubricated to warrant smooth operation and reduce friction.
3. Belt Tension
Set and Check Tension
Belts play an essential part in the movement system of the Voron-inspired printer. As time passes, belts may expand or become loose, affecting the print quality and precision.
Make sure to check the tension of the belts regularly by pressing on the center of the belt using your fingers. It shouldn't deflect more than one millimeter. Adjust the tension as needed by tightening or loosening belt tensioners.
Inspect for wear
Examine the belts for signs of wear, such as cracks or fraying. Replace damaged or worn belts to ensure optimal performance.
4. Cleanliness
Normal Cleaning
Ensure your printer is clean to keep dust and other debris from affecting the quality of prints. Clean the outside of the printer and wash the printing bed every time you use it. Use a soft, gentle cloth and isopropyl alcohol to clean the bed's surface; however, avoid harsh chemicals that may harm parts.
Interior Cleaning
Regularly clean the inside of the printer to remove filament particles and dust. Use compressed air to blow away dust from electronic and moving components. Be careful not to blow directly on sensitive components.
5. Electric Connections
Verify Wiring
Check the electrical wiring and connections for evidence of wear and damage. Frayed or loose wires may create electrical problems or short circuits. Ensure all connectors are securely connected and wires properly routed to prevent interference with moving components.
Firmware Upgrades
Check regularly for firmware updates to your board. Firmware updates could favor bug fixes, performance enhancements, and new features. Follow the manufacturer's guidelines on updating the firmware to ensure stability and compatibility.
Conclusion
The Sovol SV08, inspired by the Voron 2.4, offers a remarkable combination of performance, ease of use, and affordability. With 90% of its pre-assembled design, cost-effectiveness, and strong performance capabilities, makes it desirable for beginners as well as experienced 3D printing users. Furthermore, its open-source character, along with a wide array of possibilities for upgrades and modifications assure that it can adapt to the needs of users and talent.
Cart 0
Your cart is currently empty.
Start Shopping
