Skip to content
Sovol SO-2 Laser Engraver Pen Plotter Help Guide
SOVOL SO-2  HELP GUIDE
  • Introduction
  • Learn Structure
  • Assembly
  • Tutorial
  • Circuit Wiring
  • User Manual Download
  • FAQ
Introduction
Sovol SO-2 help guide
Sovol SO—2 is a machine that  helps  to  make your  creative  idea into reality. There are mainly four functions of Sovol SO—2, including loser engraving& cutting, writing& drawing.
With the Laser Module, you could engrave wood, paper, leather, stainless steel, ceramics and other materials; You could also cut paper, wood board, leather, and acrylic.
With the Writing Module, Sovol SO-2 supports writing or drawing on paper, cards, book pages and any surface. And you can write with your favorite pen for special design.
All of art works made by Sovol SO-2 can be decoration or using for growing bussiness.
Learn Structure
Sovol SO-2 structure Sovol SO-2 structure Sovol SO-2 structure
1 Electrical Box;
2 Power Switch;
3 Power Indicator;
4 USB Interface;
5 Power Cord Interface;
6 Y-axis Motor;
7 X axis Motor;
8 X-axis Belt Tensioner;
9 Y-axis Limit Switch;
10 X-axis Limit Switch;
11 Finger Screw Nut;
12 Thumb Screw;
13 Y-axis Support Plate;
14 Z Sxis Motor;
15 Thumb Screw of the Fixed Pen;
16 Pen Angle Adjustment Screwsx2;
17 Z Axis Handle
Assembly
Watch Sovol SO-2 unboxing and assembly video to assemble SO-2 in case any error happened.
1. 0:00-0:37    Check out Sovol SO-2 Parts List
  • Y axis  Assembly
  • X axis Assembly
  • Y axis support plate
  • Laser Head (Depends on your option)
  • Goggles
  • Pen Holder Assembly
  • Writing Board
  • Pen
  • Tool Bag
  • Power Adapter
  • Power Cable
  • USB cable
  • Micro SD Card
2. 0:41-1:51    Assemble the body
Note: Make sure that X axis and Y axis are level
3. 1:53-2:47   Assemble the Writing Module
4. 3:33-4.14   Assemble the Laser Module
Tutorial
Writing
1. Download and Intall Inkscape software
Step 1: Copy the folder in the SD card to “local computer”; and install the software as shown in the figure.
Step 2: Find inkscape.exe under the installation path: C:\Program Files (x86)\Inkscape\bin, and open the software.
Install Inkscape Install Inkscape
Install Inkscape Install Inkscape Install Inksape
Cart 0
Your cart is currently empty.
Start Shopping
