2. Lower Nozzle Temperature
PLA 180–220°C 50–60°C
ABS 210–250°C 90–110°C
PETG 220–250°C 70–80°C
TPU 210–230°C 30–60°C
3. Increase Travel Speed
Adjust in Your Slicer:
Nozzle Cleaning Steps:
5. Keep Filament Dry
How to Prevent Wet Filament:
Final Thoughts
发表评论
在发布之前,所有评论都会进行调节。
博客文章
查看全部
Why the First Layer Matters: Foundation for Successful 3D Prints
The first layer 3D printing is key to stability, adhesion, and quality. Learn how to fix common issues and achieve perfect first layers for successful prints.
How to assemble 3D printed parts
Learn how to assemble 3D printed parts with precision. From preparation to alignment and bonding, ensure durability and professional-quality results.
How to Optimize 3D Printing Tolerances for Better Results
Optimize 3D printing tolerance to improve accuracy, ensure proper fit, and reduce errors. Learn key factors like printer type, materials, and calibration.
