Sovol SH01 Filament Dryer vs Sovol SH02 Filament Dryer
Comparing Two Sovol Filament Dryers
Features
Max Heating Temperature
Heats up to 50°C.
Heats up to 70°C.
Heating Power
40W power consumption.
150W power consumption.
Heating Speed
Takes longer to heat.
Reaches 70°C in 25 minutes.
User Interface
2-inch LCD screen.
3.9-inch touchscreen.
Filament Compatibility
Best for PLA and PETG.
Supports multiple filament types.
Sealing System
Silicone seal.
Triple ring sealing system.
Drying Duration
6 to 12 hours.
Up to 98 hours.
Safety Features
Basic safety features.
Includes overheat protection.
Price
$45.00.
$59
Choosing between the Sovol SH01 and SH02 3D printer filament dryers can be hard. It depends on what you need. The SH01 is great if you want to save money or dry filament sometimes. It is easy to use, heats up to 50°C, and dries for up to 24 hours. The SH02 is more advanced. It has a strong 150W heater that reaches 70°C. This makes it perfect for fixing moisture issues in wet places or with delicate filaments.
Each model suits different users. The SH01 is best for casual users or those on a budget. The SH02 is better for experienced users who need more control and power. Whether you want to keep your 3D printer filament in good shape or deal with moisture, Sovol has a dryer for you.
  • The Sovol SH01 costs less and works well for beginners.
  • It dries basic filaments like PLA and PETG easily.
  • The Sovol SH02 has more features, like a touchscreen.
  • It can reach higher temperatures for tougher drying jobs.
  • The SH02 is great for experts or very humid places.
  • Both dryers remove water, but the SH02 works faster.
  • The SH02 handles more filament types, like ABS and TPU.
  • Pick the SH01 if you want simple and cheap drying.
  • Choose the SH02 for better accuracy and stronger performance.
  • Both are simple to use, with SH01 having an LCD screen.
  • The SH02 has one-touch buttons for quick and easy control.
Overview of Sovol SH01 3D Printer Filament Dryer
Key Features and Specifications
The Sovol SH01 filament dryer has many useful features. It can hold two 1kg spools at the same time. This is great if you like switching filaments during projects. You can adjust the temperature between 40°C and 50°C. This helps you dry different types of filament properly.
It has a 2-inch LCD screen that is easy to read. The screen shows the temperature and humidity inside the dryer. A silicone seal and cable cover keep moisture and dirt away from your filament. You can set the drying time from 6 to 12 hours. This gives you options based on your needs. The dryer also works as a storage box, keeping your filament dry and ready to use.
Pros and Cons
Here’s a simple list of what’s good and not-so-good about the SH01:
Pros
Cons
Holds two spools at once
Heating isn’t very strong
Has preset heating cycles
Only heats up to 50°C
Easy-to-use LED screen
Lets you use spools directly inside
Space for silica gel packets
The SH01 is affordable and works well, but its heating range might not suit advanced users.
Best Use Cases and Target Audience
The Sovol SH01 is perfect for casual 3D printing fans or those on a budget. It’s great for storing and drying filament in mildly humid places. If you use common filaments like PLA or PETG, this dryer will work well for you. It’s simple and easy to use, without extra complicated features. Whether you’re getting ready for a big print or just keeping your filament in good shape, the SH01 is a solid choice.
Overview of Sovol SH02 Precision Temperature Control Filament Dryer Box
The Sovol SH02 is made to keep filament dry. It has a strong 150W heater that spreads heat evenly. This helps dry filament well. It heats to 50°C in 7 minutes and 70°C in 25 minutes. You can use it for many filament types like PLA, TPU, PETG, and ABS.
The SH02 has a 3.9-inch touchscreen that is easy to use. You can pick drying settings with one touch. Its triple ring seal keeps moisture out. It also checks the temperature all the time for steady drying. Safety features like overheat protection and fan checks make it safe to use.
Here’s a quick look at its main features:
Specification
Heating Power
150W with even heat distribution
Heating Speed
50°C in 7 minutes
70°C in 25 minutes
Overheat Protection
Stops at 130°C, restarts at 90°C
Sealing System
Triple rings to block moisture
Touchscreen
3.9-inch screen for simple control
Real-Time Monitoring
Tracks temperature, fan, and mainboard status
Temperature Settings
Works with 9 filament types
Pros and Cons
The SH02 has advanced features for serious 3D printing fans. Here’s a list:
Pros
Cons
Heats fast with a wide temperature range
May not fit very large spools
Keeps track of safety features
Triple seal stops moisture
Easy-to-use touchscreen
The Sovol SH02 is great for people who need precise drying. It’s perfect for humid places or delicate filaments. The steady heat and moisture control keep filament in great shape. It’s ideal for frequent users who want reliable and advanced tools. Whether you’re a pro or a hobbyist, this dryer will improve your 3D printing projects.
Side-by-Side Comparison of Sovol Filament Dryers
Feature Comparison (Drying Capacity, Temperature Control, Ease of Use)
The Sovol SH01 and SH02 dryers are made for different users. The SH01 is simple and practical, while the SH02 is advanced and powerful.
Sovol SH02
Sovol SH01
Heating Method
PT Heating
PT Heating
Max Heating Temp
70℃
50℃
Set Duration
98 hours
24 hours
Power
150W
40W
Working Temperature
40-70℃
40-50℃
Screen/Buttons
Touchscreen
Spring-loaded buttons
Fan Type
3-wire self-checking fan
2-wire non-self-checking fan
Filament Preset
PLA, PETG, PC, ASA, ABS
None
Expandability
External air pipe connection
None
The SH02 heats up to 70°C and uses 150W power. It’s great for drying filaments like ABS or TPU that need extra care. Its touchscreen makes it easy to use. The SH01, on the other hand, is smaller and cheaper. It heats up to 50°C and has simple buttons. It works well for PLA or PETG filaments.
If you want preset options for different filaments, pick the SH02. But if you prefer a basic and affordable dryer, the SH01 is a good choice.
Performance Comparison (Drying Efficiency, Noise Levels)
The SH02 dries filament faster with its 150W heating system. It reaches 50°C in 7 minutes and 70°C in 25 minutes. This is helpful for quick drying. The SH01, with 40W power, takes longer but still dries common filaments well.
Both dryers use PT heating to spread heat evenly and remove moisture. The SH02 has a 3-wire fan for better airflow and drying. The SH01 uses a simpler 2-wire fan, which is fine for basic needs but less precise.
Both dryers are quiet, so they won’t disturb you at home or work.
Price and Value for Money
The SH01 costs $45.00 and is budget-friendly. It’s perfect for casual users or beginners. The SH02 costs more but offers advanced features like a touchscreen and higher heat settings. If you use many filament types or live in a humid area, the SH02 is worth the price.
Choose the SH01 if you need a simple, low-cost dryer. Pick the SH02 if you want more features and better performance.
Choosing Between the Sovol SH01 and SH02 3D Filament Dryers
Picking between the Sovol SH01 and SH02 depends on your needs. The SH01 is cheaper and great for beginners or casual users. It’s easy to use and works well with filaments like PLA and PETG. The SH02, however, has advanced features like a touchscreen and higher heat levels. This makes it better for experts or people in humid areas.
If you want something simple and affordable, pick the SH01. If you need more power and precision, the SH02 is a smart choice. Both dryers keep your filament dry for great printing results.
What’s the main difference between the Sovol SH01 and SH02?
The SH01 is budget-friendly and simple, while the SH02 offers advanced features like higher temperature settings and a touchscreen. If you’re a beginner or casual user, the SH01 works great. For more control and precision, the SH02 is the better choice.
Can both dryers handle all filament types?
The SH02 supports a wider range of filaments, including ABS and TPU, thanks to its higher temperature (up to 70°C). The SH01 works best with common filaments like PLA and PETG. If you use specialty filaments, the SH02 is your go-to option.
Which dryer is better for high-humidity environments?
The SH02 is ideal for humid areas. Its triple-ring sealing system and powerful 150W heater ensure your filament stays dry. The SH01 can handle mild humidity but may not perform as well in extreme conditions.
Are these dryers easy to use?
Yes! The SH01 has simple buttons and a 2-inch LCD screen, making it beginner-friendly. The SH02 takes it up a notch with a 3.9-inch touchscreen and one-key presets for different filaments. Both are designed for hassle-free operation.
How do I decide which dryer to buy?
Think about your needs. If you’re on a budget or print occasionally, go for the SH01. If you need faster drying, higher temperatures, or live in a humid area, the SH02 is worth the investment. Both deliver excellent results for their price.
