Thermistor Error
If your printer has triggerred a thermistor error, it might be something went wrong during the hot bed or hotend heating up.
1. A step to confirm whether the error caused by the hot bed or the nozzle. Heat up the hot bed to 80 degrees alone to see if would trigger the error.Then heat up the nozzle to 200 degrees alone to see if it would trigger the error.
2. Check if there is any looseness or damage appears on the wiring of the heating port from the mainboard.(Looseness of the wiring might be caused due to many reasons, like movement of the printer and etc.)
3. Check whether the power supply has been adjusted to meet the local voltage.
4. Swapping Test:Please exchange the heating wires of the hot bed and the nozzle on the main board to perform the heating test.
- If it is the problem with the hotbed heating up, then move the hotbed heating tube to the nozzle heating port on the motherboard, and set the temperature of the nozzle to 80 degrees and see if it would trigger the error.
- If it is the problem with the nozzle heating up, then move the nozzle heating tube to the hotbed heating port of the motherboard, and set the temperature of the hotbed to 80 degrees and see if it would trigger the error.
Note: A note when heating the hot bed:
Please note that when heating the hot bed, we can not put cold objects on the hot bed during the heating process or after the heating is completed, which is very likely to cause a sudden drop in the temperature of the hot bed and causing the thermistor errors;
For example, when we remove the cold soft magnet, then heat the hot bed, and then put the cold soft magnetic sticker on the heated hot bed. The temperature of the hot bed will drop sharply and causing the thermistor error.
Frozen Screen
1. SD Card: Check if there is any firmware type file (The motherboard firmware with the suffix bin and the screen firmware with the suffix diwn_set) left in the SD card before printing? If yes, please format the SD card to Fat32 format first.
2. If the problem still goes on, then refresh both motherboard firmware and touchscreen firmware again.
Abnormal Fan Noise
If there is a abnormal noise appear on the printer, please confirm whether it comes from mainboard or the extruder.
1. Check whether there are any debris or wires interfering the fan rotation.
2. Check whether there is any damage appear on the fan blades.
3. Check whether there is any deformation appear on the fan cover and the bottom of the gantry.
Please follow the steps above for troubleshooting and provide result and a video of the noise with us. We would confirm the problem and provide correct solutions or replacement(if needed) on this issue.
Not Reading SD Card
If the SD card can not be read by the printer, you may encounter one of the problems listed below.
1. Incorrect Name of the STL; The name of the STL should not exceed more than 16 characters and with no special symbols.
2. Problem With the SD Card;
-The SD card should be formated to the FAT32 format;
-The memory of the SD card should be less than 16GB;
-Check whether the SD card can be read by the computer;
-Use alcohol or an eraser to wipe the metal antenna of the SD card and try again to see if it can be read.
What material was the original heat shroud (the air guide) printed with?
The air guide is printed with PLA filament, you can make a few more spares.
SV01PRO flash firmware tutorial:
https://docs.google.com/document/d/1au1YpSzFVfLCmFNHF4EJ_wLbIBUcU9zQ/edit?usp=sharing&ouid=116699464694286068058&rtpof=true&sd=true
After installing the latest firmware, you are unsure how to get the printer to be recognized by your macbook M1
Connect the computer with the supplied usb cable and check if the device manager shows the port, refer to the picture. There is a display is connected.
The tutorial on disassembling the SV01PRO hotend to clear a clogged hotend
https://www.youtube.com/watch?v=Lx5ndVX-l6k&t=42s
17 comments
Half way through a print run started to run strings. Finished the print 2 of the 3 prints came out 3d one all stringy. Started an new print and print will not stick to bed and just creates a giant ball of string Svo1 pro printer
Can I buy replacement extruder sv01pro
I have downloaded the profiles for the SV01 Pro o use in cura but dont know how to import them Cura says they are corrupt
I had a failed print over night due to my own errors, I melted the plastic cover in front of the nozzle its not the heater block. but it front of that. please help I love this printer and I want to replace the part asa.
Wow, happy to see this awesome post. I hope this think help any newbie for their awesome work. By the way thanks for share this awesomeness from Feel free to visit my website ! 먹튀 검증 순위 안전 카지노 코인 카지노 안전 토토 사이트 먹튀 검증 커뮤니티 https://www.j9korea.com
I bought an sv01 pro and everything was good…until I printed an Ironman helmet. I’ve printed the piece several times due to the nozzle hitting the print. My bed is manually and auto leveled every time I print and it works fine. Only issue is when my print is tall it starts shifting and hitting the nozzle.
my controller fan under the printer is making a lot of noise when it fires up.it is a 24v small little fan. we can hear about 2 rooms away . please advise.
I have a brand new printer that I set up on dec 28, the filament sensor keeps throwing an error and pausing to say I need to change the filament but there is plenty on the roll left! It is interrupting all my prints and I have no idea what to do. This is a brand new machine and there is already issues?
Houston and William have you figured out a soultion for your problems, I am having same problems with my sons sv01 pro. I just want to get this up and running since it was a christmas gift.
First print was great second print started to go crazy after the 3 hour mark. The nozzle seemed to be clogged. Very thin stringy lines of PLA were coming out of nozzle. I tried to purge to no avail. Next thing the screen showed, “Heating failed”. I shut it off and back on. Screen will not go away. I can’t do anything. Even if I unplug it, when I turn it back on the "heating Failed message appears. I did disassemble the heating tip and cleaned and put back together. I still getting heating failed message. What should I do? Did the heat fail at the nozzle? Not happy, second print ever on this thing.
Ive owned my Sovol SV01 Pro for a month now and it just started to stop saving the bed leveling info. After getting bed leveled and do a successful print it will not keep mesh leveling info saved. Please help
I purchased the SV01 pro and I cannot get anything to stick. I have leveled it many times, temp is good but I think its the hot end that is causing the issue. Can someone help
I bought the Sovol SV01 Pro from amazon. I still want to buy the build record on your homepage. But I also needed the filament holder… where can I get it?
Hello, during a print during a trip the cables of the hotend were torn off. Please let me know the procedure to follow. Thanks
Hey dear support, I have had the Sovol SV01 Pro for a few days and unfortunately I can only adjust 0.05mm in the Z Offset. With the SV03, however, you can change the Z offset with 0.01mm. Am I doing something wrong or is there somehow a hidden option that I can not find. Greetings Kamran
Das Einbinden des Druckers im Slicer ist eine echte Frechheit. Bei der Einstellung nacheinander drucken, hat sich der Druckkopf in ein fertiges Model gefahren und den Touch Sensor zerstört. Ich brauche keinen Ersatz mehr, da die Wartezeit auf bestellte Teile mir zu lang ist. Vielleicht schafft es ja mal einer, ein angepasstes Slicer oder Curaprofil zu erstellen. Ich habe jetzt mein Profil angepasst. Es waren ganze 10 Minuten. Inklusive Anleitung suchen mit google. Ach ja und verwendet doch bitte etwas wertigere Lüfter für die Drucker. Die Hotends vom SV04 passen ja in den SV01 pro, aber die Kabel nicht! Ansonsten setzt unter der Y Achse noch eine Distanzscheibe. Bei mir war die Achse verdreht durch die Verkleidungen. Die Lager sind dadurch sehr schnell defekt geworden. Auch hier kein Ersatz mehr nötig. Alles nur Kleinigkeiten aber sehr ärgerlich, da es mein erster 3D Drucker ist.
